Thread: Closing AGP - what is shock level?
    Feb 2013
    Nashville, TN
    49
    We are preparing to close our saltwater AGP for the first time. I have read the instructions in pool school and various other pool articles. All of them say to bring the pool water to "shock" level. However, none of them explain what the heck "shock level" is. Currently our FC is about double what it normally was during the summer. Here are my latest test readings:
    FC: 9
    Ph: 7.6
    TA: 80
    CYA: 45
    Am I good to close with these readings?
    Sharkline Matrix 28', Pentair SD80 sand filter, Pentair Optiflo 1hp/2spd pump, Intellichlor ic40 (installed 7/2013)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Closing AGP - what is shock level?
    Please refer to the Chlorine/CYa chart in Pool School.
    38,452
    We now call is SLAM level, but as woody said, you can find the chart in Pool School here: pool-school/chlorine_cya_chart_shock
    It is a function of your CYA level and for you it would be around 18ppm.
    Feb 2013
    Nashville, TN
    49
    So, if I'm understanding this correctly, I need to dump approximately 3 gallons of chlorine into my saltwater pool prior to lowering the water level and closing?
    38,452
    Sounds reasonable, although I did not check the dose with PoolMath.
    38,452
    Estimating you volume at 18k, to raise the FC from 9ppm to 18ppm would require two 121oz bottles of 8.25% bleach or 2.75 gallons of 6%.
