Results 1 to 7 of 7
Thread: New Pool Light...
    May 2011
    Abilene, KS
    67
    New Pool Light...
    I have an old 12 volt pool light that was most likely original to the pool (1979) that stopped working. The pool company came out today and found that the socket is no good; tab is broke off and porcelain socket is cracked in several spots.
    First question... What is the best light to replace it with?
    2nd question... How hard is the raplacement to accomplish?? The transformer for the current light is almost 70 feet from the light and around a corner! I figured there would surely be a junction box some where before the cord makes the bend, didn't find one, unless it is under the diving board...
    25,000 gallon Vinyl Lined Inground. One skimmer, 2 returns. Pentair WhisperFlo WFDS-4, Hayward Pro Grid DE 3620 with VariFlow valve, LaarsLite 2 propane heater
    38,475
    Re: New Pool Light...
    There should be a deck box close to the light above water level where the wires from the light are connected to the wires from the power supply (at least that is how 120V lights are hooked up). It is also fairly common the deck box to be under the diving board.
    Mine was not under the diving board, but I found it under an overgrown bush about 10 feet from the light.
    May 2011
    Abilene, KS
    67
    Thank you. I'm going to operate (for now) under the assumption that the box is under the diving board. When I bought the house there was nothing planted around the pool, just gravel so I'm certain there is not abox any where else.
    May 2011
    Abilene, KS
    67
    Any advice on replacement lights?
    30,431
    are you pretty confident it is a 12v light? That's unusual for a pool of that age.
    If it is 12v, the light may go to the house or possibly and outlet on a nearby building.
    May 2011
    Abilene, KS
    67
    I'm sure it's a 12 volt. The transformer hangs on the wall by the pool equipment.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You are restricted to lights that will fit your current niche unless you want a fairly significant project to change the niche.
    Lights routinely come with 100ft cords, so it is very possible that the transformer is the only connection on the light.
