Thread: How to lube a Jandy NeverLube valve
    Drew80's Avatar
    Feb 2013
    Austin, TX
    106
    Ok, so that sounds like a contradiction, but I have one NeverLube valve that is REALLY hard to turn. I'd like to open it up and lube it. Is that a bad idea?
    7,500 gallon gunite pool. 1,100 gallon spillover spa. Prologic 8. T-Cell 15 SWG. Hayward 350k BTU heater. Hayward cartridge filter. 2 HP Tristar pump. AquaConnect. TF100
    Re: How to lube a Jandy NeverLube valve
    It most likely just needs to be taken apart and cleaned, but using a silicone based lube such as Boss 820, Magic Lube II (Not regular Magic Lube), or Dow 111 should be helpful.
    There is a set-screw that locks the handle in place. Make sure that the set screw is loosened before turning the handle.
    Also, note that the NeverLube come with a lifetime guarantee. If the valve won't work after cleaning, Jandy might help you out with this.
    http://www.zodiacpoolsystems.com/Produc ... alves.aspx
    Support the site
