View Poll Results: How many people use PolyQuat/algecide when closing pool?
Voters
30. You may not vote on this poll
  • yes
    13 43.33%
  • no
    17 56.67%
Results 1 to 17 of 17
Thread: How many people use PolyQuat/algecide when closing pool?
    Oct 2010
    michigan
    284
    How many people use PolyQuat/algaecide when closing pool?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    Re: How many people use PolyQuat/algecide when closing pool?
    This is the first year we are closing using BBB method recommendations vs. pool store method. (been with BBB exclusively 2 seasons now but - dah - did not seem to find BBB closing recommendations till this year). Every previous year - 5 - we've followed the pool store advice and opened to a green pool each and every time. Since we still have a few bottles left over from the conversion, we will use the polyquat till it's gone. I am pretty confident we will open to a clear pool. Thanks to BBB and TFP!
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I don't use it.
    Smykowski's Avatar
    Sep 2011
    3,065
    Me neither. Close late and open early with only liquid chlorine.
    Sep 2009
    Frederick County, MD
    185
    No here as well. 5 yrs using BBB.
    Open in mid-April, close in mid-October, run it up to a little above shock and open to a clear pool.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    May 2013
    Long Island NY
    419
    I don't use it either, my pool has the loop lock on but the pump still runs 2 hrs a day until the water gets below 60 then I pull the pump and blow out lines. Nothing else added.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Oct 2010
    michigan
    284
    do you guys have solid covers or mesh covers?
    My problem is I have a mesh cover so some sun gets thru
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have a fine mesh cover, but it blocks the sun pretty good. Also, in my climate (and maybe yours?), the pool freezes solid, so nothing organic happens during that frozen period.
    Oct 2010
    michigan
    284
    yes shocked at closing in mid October. but still ended up getting green in the spring, started turning green under the ice.
    think I'll try that way again this year, but top off the shock level before it freezes, have one of those robots to stir up the water.
    I have a solid cover and take it to shock level when closing in mid October, opening in April there's usually 20-30% of my shock value remaining.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by smooth2222
    Make sure you pass the OCLT (and CC and water clear) before closing it up.
    May 2013
    Fort Lauderdale, FL
    423
    I closed my pool "early" on Sept 19 because of the overhanging trees and mass amounts of leaves falling. Brought to shock and did polyquat 60. That was about a month ago. I pulled up the corner of my new solid loop-loc cover with mesh drains and the pool was up to normal level of water (closed 15" lower than deck height). We just had 4 inches of rain. So while I was pumping out water with a sump pump, I stuck my head down there to check things out. Water is still as clear. Sunlight does get through the solid cover- you can see all the way across the pool (45'). So it's not dark under there, but filtered light. Water temp is 65 right now because of warm weather we've been having. I don't think the poly hurts- I was expecting it be green already.
    The reason I closed early is because I got tired of seeing this every morning:
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jul 2008
    Flintstone, GA USA
    112
    Don't use that brand but I do use a Algacide 60 along with my shock. I have a solid loop loc cover and have never had any problem with my pool. It is always as clear when I open it as it was when I closed it. Only thing I do have is a few earth worms on the bottom. I just don't know how to keep those suckers out.
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    For a pool with a chlorine generator, just run it on superchlorinate until the level is up to shock before closing? This is after passing the OCLT. I will be using a mesh cover. My pool temp just got down below 60 degrees.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    New Brunswick Canada
    819
    Highly not recommended to use superchlorinate, you are shortening the life of your cell. Why not keep it at normal settings, the chlorince will rise if covered, then you can add $10 bucks worth of Bleach to boost that level, I know I have never used more then 20% setting and my cell is still good, others have used superchlorinate and replaced cells very quickly.
    Good point. I have been running mine at 40% for 6 hours per day. I have to admit I haven't checked the levels in a while so I don't know for sure where it is right now but since it is colder and covered it must be higher.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I am closing tomorrow (pool co closes but I ask them not to do the chem) but pool store was out of polyquat60.
    This is only my second year closing...I am debating just going without since I am shocking but with my high phosphates due to steady diet of jacks magic I am a little nervous about the idea...(eg lots of food if warmth ramps up early, though I do plan to open in April...)
    Thoughts?
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
