Thread: How to fill Expansion joints in pool deck (pics)
    So my pool deck has plastic strips (zip strips) placed in the expansion joints that are now worn out and coming apart. It looks ugly and I think it is not fulfilling its function. I want to rip the plastic strips out.
    I was wondering what would be my best bet to replace it with. Mastic, DeckO Pool or a Self-leveling Polyurethane caulk (Sikaflex etc).
    I am leaning toward the Sikaflex but am not sure how it will withstand the water and the chlorine in the water.
    Anybody has experience with this would like to chip in their thoughts. Thank you.
    [attachment=1:358odqwf]_MG_8303.JPG[/attachment:358odqwf][attachment=0:358odqwf]_MG_8304.JPG[/attachment:358odqwf]
    Inground Concrete/Plaster Diving Pool, 17X30 ft, 20k gallons, 1 skimmer, 1 main drain, 5 returns,
    1 HP (SF 1.25) STARITE SINGLE SPEED, 2-Speed, 1 HP Pentair Superflo (not yet installed!) Hayward Sandfilter 3.14 ft.ft
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: How to fill Expansion joints in pool deck (pics)
    Just FYI, it looks like those were put in for drainage. No matter what you use you will loose the drainage feature.
    chiefwej
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Yup, those are draining channels for sure. Can you replace them with the same size channel? Would it look horrible to remove them all together and leave the channel open?
    You might get some loose debris in there which might need occasional cleaning out but you wouldn't lose the entire channel's purpose.
    Hmmm, do not want to lose the drainage if that is important... not quite sure of what how it functions... drainage from where... the channels do not lead into the pool... or seem particularly graded.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Here is a website from the guy I'm going to use to caulk my new pool and other joints around the pool deck. After talking with several pool builders, they feel this is the highest quality way to fill these gaps. It's a non-sag (i.e. non-self-leveling) caulk and they also use a professional grade urethane sealant on it. It's one of several options for such gaps, though doesn't do anything for drainage obviously, except directing it elsewhere, which is the point of caulking.
    http://www.caulking-unlimited.com/
    Regarding your joints and potential drainage, it should easy enough to evaluate your deck to see where the water is really going. It doesn't look like much is getting in those openings any longer. They appear full of debris and are too tiny to carry any significant volume of water that a storm would bring. I would doubt they are serving any large drainage purpose as they are just too small. A hose and a little testing should let you know where the water all goes. I would expect that little drainage is occurring with them a quality caulking job of the joints would look great.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Thanks bmoreswim, thats a good site. Seems like gun-grade is the way to go. I am looking at my deck and patio and you are right, there is not much that the drainage channels are doing. Will test more later today but I do not think I will lose much by caulking them up.
