Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Planning stage for new pool
    Sep 2013
    Nashville, TN
    379
    We are in the planning stage for a new vinyl IGP to start late winter/early spring next year. We will likely be adding a small 1/2 bath as part of the project and trying to decide where to place the pump and equipment. We will likely keep the pool open year round so not sure if that would play a part with this decision.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: Planning stage for new pool
    Welcome to the forum!
    Sep 2013
    Nashville, TN
    379
    Any recommendations on a pool builder in the Nashville that works with DIYers?
    30,402
    Welcome to the forum.
    When I placed my equipment, my primary concerns were aesthetics and noise level. Mechanically, it should ideally be a foot or so above the level of the pool water but it can be a pretty long way from the pool if that's the best place for it.
    Can't help with anyone around Nashville....sorry.
    Sep 2013
    Nashville, TN
    379
    I am meeting with a PB this week to see how what we want to do matches up with their thoughts and experiences. We are currently looking at 18x36 rectangular vinyl with 10' roman steps at each end and sports depth. We are also looking at adding a sunledge on the side. I am leaning towards no main drain with 2 skimmers on the down wind side and the 3 returns on the opposite side and jets on the steps at each end. I am also leaning towards 4 Savi LED lights in each corner. My wife is wanting some type of water feature, we have looked at either deck jets or I found some spray jets that go above the water line inside the pool. How does this sound, what size 2 speed pump would be sufficient? Once I get this nailed down I will be giving my drawings to our architect to clean them up for permit and HOA approvals.
    Sep 2013
    Nashville, TN
    379
    I am trying to decide between using white or blue steps, if we go with white then the will match the sun ledge, but I think the blue ties in with the liner better. Any thoughts? Also, has anyone with colored steps experienced them fading?
    Sep 2013
    Nashville, TN
    379
    He also suggested a single speed pump running 24/7 instead of variable or 2 speed pumps, does that sound right? I'm sure when I get the quite back there will be more questions.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    This is a classic case of a PB not giving out sound information on running a pool. I wouldn't put much stock in his chemical suggestions given the pump runtime comment (that and TFP is your place for all these answers). Almost certainly a 2-speed pump running way less than 24/7 will be your best bet. But just to be sure, what is your electricity rate?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Sseaman
    Looks like bmore beat me to it, but here are my thoughts:
    Quote Originally Posted by Sseaman
    Only if you want to needlessly spend more money on electricity
    Definitely go with at least a 2-speed pump. Most the time you will run on low...and if for some reason you wanted to run 24/7 (most pools only need a few of circulation), then low speed for sure.
    I don't see any water features in your plan? If not, then you should be able to go with a fairly small 1 hp 2-speed pump such as the pentair superflo.
    Sep 2013
    Nashville, TN
    379
    Electric rate is $.09234 per kWh and we are not looking any water features. The dig sheet show approx 24k gallon for the size and depth we are looking at. I was also concerned that he has not dug a sports pool before but I'm not sure that would be a huge issue. When talking with him some of the stuff he suggests are in line with things I have read on TFP, unlike other PBs that are giving the hard sales pitch.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I think for 2-speed pumps, the pentair superflo model:340042 or the Hayward Superpump model SP2607X102S (the Hayward is a little lower flow and power, so it might be a better choice, though pentair has a lower flow superflo pump as well model 341111, but that one tends to be harder to find). If you are going to consider a vs, look at the Hayward Superpump vs or Maxflo vs pumps.
    Sep 2013
    Nashville, TN
    379
    Linen thanks for the info, should I look at 1hp or 1 1/2hp for the 2 speed pump? Also, what size cartridge filter would be best?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    No larger than 1 hp (full rated) since you have no water features that require it. See the models I posted above. Another pump to add to the mix is the Hayward maxflo xl model SP2307X102
    For a 24k gallon pool, looks like you'll want a 350 sq-ft cartridge filter: hydraulics-101-have-you-lost-your-head-t915.html
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by danacc
    I concur
    Sep 2013
    Nashville, TN
    379
    Thanks guys
    Sep 2013
    Nashville, TN
    379
    I may have to look for a different PB, I showed him my sketch the day we meet and even offered for him to take it along, it has taken 4 tries for him to send over a CAD drawing that is even close to what I told him I wanted.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    I feel your pain.
    trust me...
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Based on comments above and especially this, I agree and would start looking. If he can't/won't pay attention to your wishes on the basic design
    you are hosed. IMO anyway...why would he not pay more attention? No reason, unless he just doesn't care, or thinks he has a better idea.
    Either way is bad, and I would imagine it will be this way on everything.
    Essential Links:
  20. Back To Top    #20
    Sep 2013
    Nashville, TN
    379
    Looking at fiberglass steps on both ends would you put jets in them to help keep them clean?
