Thread: Opinions/Advice on refinishing
    Jul 2011
    North East
    135
    Hi all,
    As it turns out the pool needs to be refinished. It was completely re-plastered about 3 years ago (prior to us purchasing the house) and it appears as tho the finish is shot. There is one plaster pop in the shallow end which I previously posted about and I can feel several more forming. The prices I have received to re-plaster are in the 5-6k range. I've also had a rough estimate given for putting a liner in the pool which would come in around 5k.
    What are the pros/cons for each? Mainly I'm looking for DURABILITY. I don't want to be messing with this again in a few years. We aren't overflowing in cash money and this is something that I don't want to keep dealing with.
    Thank you
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Opinions/Advice on refinishing
    Don't go back with the same company for sure, and do not go back with straight plaster. Your plaster should have lasted longer than 3 years but it was likely installed poorly. Either that, or you have had some really bad water chemistry. Even if so, I would still bet you had a bad installation.
    Go with a good quartz finish at minimum. Based on your comments about budget, pebble may be out of your range, but a quartz finish will last a very long time. CLI, Wet Edge, and National Pool Tile all offer very good quartz products.
    Essential Links:
