Thread: The best energy eficient small pump
    I have a small 1,800 galons spa with a water feature that is only turn on when needed. Sand filter that reads 31.5 usgpm and about 30 feet of head to the pump.
    Energy cost here are us$0.26 per kw
    Please advice.
    Thanks for the advice
    Ricardo
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: The best energy eficient small pump
    Welcome to tfp, Rtaule
    Do you have a pump currently? If yes, what model and why do you want to replace it?
    For use to recommend a pump we will need to know more details, for example, how many and what diameter are the spa jets.
    Thanks for the help.
    Who did the spa i dont think knew much and installed a 2 hp pump wich draws 11.5 amps :hammer
    The spa has 7 3/8" jets.
    Please let me know if you need more information.
    Best regards
    Ricardo
    mas985's Avatar
    Pleasanton, CA
    11,737
    You don't want to downsize a spa pump or the jets will get much weaker. A 3/8" jets requires 15 GPM each in order to feel moderately strong. So the pump needs to produce at least 105 GPM which only a 2 HP or larger pump can do.
    But you really should not need much in the way of run time per day for such a small amount of water. The spa will turnover in less than 20 minutes so I doubt you need more than that per day. How much are you running the spa per day?
    Mark
    Thanks Mark
    Im running it 1 hour per day
    Regards
