Thread: Cleaner pump stopped working
    I have had an iAqualink for almost a year now with no issues. Over the summer I noticed bearing noise on my cleaner pump. I came home one day and it wouldn't come on. I figured the motor was fried so I just replaced it with a brand new one. But... It still won't come on. The light comes on indicating it should be pumping, but nothing is happening. Did something happen in the board? Is there some kind of fuse?
    Thanks!
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Cleaner pump stopped working
    Motor bearing has probably developed into a motor failure. Confirm that you have voltage at the back of the motor. If so, replace/ repair the motor.
    Factory Warranty Station for:
    I replaced the pump motor over the weekend. No luck. I can hear a click at the relay when it tries to kick on. Ordered a new relay. If that's not it, I'm down to the board I guess.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Verify you have voltage at the relay "line" side.
    Verify the breaker has not tripped One line of a dual breaker tripped may not look like it has tripped. Set breaker to off, then back to on to reset properly.
