Thread: Replacement spring covers for solid Cover
    Aug 2007
    Chesapeake, VA
    41
    Has anyone found a source for the spring covers that come with solid winter covers?
    I have seen the replacement spring covers for $5 each. OUCH! Considering the cover has over 40 springs.
    I was considering finding a source for bulk tubing.
    Anyone got any ideas?
    Steve
    27,000 gal Vinyl Grecian L, Hayward 1 HP pump, Hayward sand filter, Aqua Rite Chlorinator,
    Polaris P955, TF-100, Speed Stir, 400sqft solar panels.
    Jacuzzi J365
    Re: Replacement spring covers for solid Cover
    Most hardware stores carry clear vinyl tubing. You can take a cover to find the closest match. Here is a random example of 1.25 inch I.D tubing that costs $2.34 per foot. If each cover is 6 inches, then your cost per cover is only $1.17.
    http://www.ebay.com/itm/1-1-4-Inch-I-D- ... 183wt_1164
    [edit]The wall thickness in this example is 3/16" and would be a little too thick. 1/16" is a better choice. If the wall is too thick, then the spring will sit up too high.[end edit]
    Support the site
    Oct 2010
    michigan
    284
    what is the purpose of the cover? when it snows or rains, its still will get wet inside.
    I have the same problem where my springs are starting to rust a bit, I put a little vegetable oil to help prevent.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    The covers protect the deck from getting scratched by the springs.
    The standard LoopLoc type spring cover is about 1.25" I.D x 6 inches long and the wall thickness is about 1/16".
    The larger style of spring cover is about 1.5 " I.D x 6 inches long with a wall thickness of about 3/32".
    Support the site
