Results 1 to 8 of 8
Thread: A Big Thank You
    A Big Thank You
    I am a brand new pool owner(built in August) and I am so glad that I found this place. Of course all of the advice I received before coming here had me on track to spend a fortune to keep my pool "right". I started out using triclor and cal hypo as instructed by my pool builder. Luckily I came here before CYA got out of hand(~73 currently) along with CH(330 currently). I now have a Taylor 2006 kit and use nothing but bleach to chlorinate. I'm still trying to learn the amount that is needed but I'll get there soon enough. I tend to over chlorinate at this point according to the best guess(and other) charts so I am slowly backing down. I also added Borates via boric acid granules. My already very nice looking water became eye popping clear. Even my wife, who tends not to notice things like that, noticed as soon as she came out the door. OK, enough rambling on my first post. I just wanted to say Thank You very much to all who contribute to this great forum. The information is invaluable.
    FC-9
    CC->.5
    TA-80
    PH-7.4
    CH-330
    CYA-~73
    13,000 gal. - IG w\ attached spa
    Cartridge Filter
    Plaster w\ mini rock finish
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: A Big Thank You
    Welcome to the Forum Robert!
    Glad you found us and congratulations on getting it done. It will get easier from here and you'll love having TF Pool.
    Essential Links:
    Feb 2008
    Denton, TX
    5,061
    Re: A Big Thank You
    Welcome to TFP!. Numbers look good. Keep it up!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: A Big Thank You
    Welcome to tfp, Robert LG
    Quote Originally Posted by Robert LG
    CC->.5
    Do you mean CC greater than 0.5 like you wrote, or did you mean less than 0.5?
    Re: A Big Thank You
    Quote Originally Posted by linen
    CC->.5
    definitely <
    Cartridge Filter
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: A Big Thank You
    That sounds better
    Butterfly's Avatar
    South Carolina
    10,045
    Re: A Big Thank You
    Congratulations on taking control of your pool
    My only suggestion would be to get a speed stir, if you don't already have one.
    Swirling and swirling and counting and counting can be boring, tedious, and some of us even lose count!
    Welcome to the forum
    You're done SLAMing when:
    Re: A Big Thank You
    Speedstir just came in yesterday! I am anxious to use it tonight or in the morning. I need to test my tap water as well so I'll break it in right. My CH creeping up is kind of bothering me so I need to find out where I am at with fill water. A small drain and refill won't hurt my slightly high CYA number either.
    Thank you all for the warm welcome and unbelievable knowledge.
    Cartridge Filter
