Thread: High Speed Not Working
    mpride's Avatar
    May 2008
    Sugar Land Texas
    73
    I was having trouble with my SWCG. I replaced it and found that it still didn't work but it had a different issue. The issue had to do with the relay in the K1 position on the pcb. I re-soldered the relay and the SWGC is working like a champ. However, when I turned the power on to check the system, the pump wouldn't turn on at high speed. I can select high speed while in service mode but nothing happens. I don't hear a relay or anything. I can select low speed and it everything works.
    How do I go about troubleshooting this? Is there an easy way to isolate the problem to the relay? Is it possible the pump is having a problem?
    Mark
    IG Gunite * White Plaster * 26'9" x 14' * 310sqft * 70' Perimeter * 9300 Gallons * 2 Main Drains
    2 Skimmers * 4 Jets * Aqua Plus Control System * Aqua Rite Salt System * C3025 Cartridge Filter
    Tristar 2HP 2 Speed Pump * H400K Heater * Phantom w/Booster Pump * ColorLogic
    38,284
    Re: High Speed Not Working
    Anything is possible ... check the wires to the relays and the wires to the motor. I think there is usually a click, though, so I suspect something around the relay.
