Thread: Cover cleaning
    Apr 2008
    Burlington, WI
    67
    Cover cleaning
    I have auto-cover over my indoor pool. The cover is on rails and can be safely walked on. I have cleaned the cover with a bucket and rag or mop several times with a dilute bleach solution. Can I use a commercial product and a power washer to do the same job. I was looking at a product made by Zinsser called JOMAX (made for power washing a house), you add 3/4 of that (The ingredients are: O-phenylphenol, sodium salt 0.25% and Inert ingredients 99.75%), 2 cups of bleach and 3 qts. water.
    Any thoughts?
    Thanks.
    58,800 gal gunite INDOOR pool w/ spa
    automatic cover
    Jandy "stuff" - pumps, cartridge filter, aqua link
    CAT Controller 4000
    Stenner 30 gal (bleach) and 15 gal (acid)
    Puck chlorinator and Nature 2- gone
    Hi-Z Heater - natural gas
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Re: Cover cleaning
    Why won't you use just pure bleach with your pressure washer?
    I assume the product you described wasn't designed speifically for pool use.
    The phenyl phenol is an organic compound which may react with FC and since you don't know how it may affect your pool, why take the chance?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cover cleaning
    Quote Originally Posted by Water_man
    I don't think I'd want to spray bleach like that. It's very difficult to control with a pressure washer, even with the chemical feed nozzle, and then when you hit it with pressure it will fly everywhere.
