Results 1 to 16 of 16
Thread: Liner installation problem/advice
    not2high2fly's Avatar
    Oct 2013
    wantagh/NY
    14
    I have an in ground 16'x36' rectangle with the 8' deep end (vinyl liner about 27k gallons) last year it was harpooned during hurricane Sandy. I decided to try the all black liner, the first liner that went in came with white alignment marks that were supposed to wash away but never did and the floor of the pool was nothing but wrinkles. I contacted the installer and liner manufacturer and after sending their people over to take a look they agreed to replace it at the end of the season. I also asked the liner company if they would switch the color to dark blue instead of black and was told no problem. Last week the installation company put in my replacement liner while I was out, came home to find another black(not dark blue)liner with a less but a still wrinkled floor and a few spots on the walls. After another call the guy's came back over to fix it and told me that they had already hand troweled the sand prior to installing the liner and that was pretty much as good as it gets. I'm not sure if I'm expecting too much I realize black is harder to due but nobody ever informed me of possible problems except for the safety issues. We expected it to look like every other liner we have had, this one looks like an old lady in a bikini. I would post pic's but I don't have an underwater camera and it's very hard to see without one. Another thing is right now the pool has only a few inches of water in the shallow end and when you look at the 4 corner's the amount of liner material at 3 of the corner's is equal the 4th is much more. I was told that it will fit fine once filled, both companies have been great and I don't want to become a pain for no reason. Does anyone have any advice , had the same problem , have installation knowledge , do I have a legit gripe? Thanks for your time.
    22,544
    Re: Liner installation problem/advice
    Welcome to TFP.
    Is the liner actually wrinkled or is it divots in the floor you're seeing?
    PIctures would definitely help.
    Oct 2013
    wantagh/NY
    14
    To me it almost looks like they raked the sand /finger nail type marks. According to them it's the fold lines and packing marks from the liner company. I'm going to try to take some pic's today. Thank you
    30,414
    Based on your description, my antennae would be up. Even with just a few inches in the shallow end, your liner should be snug and tight to the floor.
    Oct 2013
    wantagh/NY
    14
    It is tight. I think that it has quite a few wrinkles for a brand new liner. Tried to take some pic's but I will have to find a way to block the sun/shadows later today. Best I can do for now.
    22,544
    Pictures can be deceiving, but that looks like an issue with the troweling of the sand under the liner. I'd call the installer back and have the owner or manager look at it.
    Oct 2013
    wantagh/NY
    14
    What about the corner's I don't think the liner is square to the pool because of the excess in the one corner.
    Oct 2013
    wantagh/NY
    14
    Do you think it's worth making a stink about or should I just suck it up?
    30,414
    Those are trowel marks...pretty sloppy. The wrinkles in the corners WILL NOT come out....that's just an opinion but the floor of the liner and the floor of the pool are not square to one another.
    I'd pull the plug if you have financial leverage. That's an inadequate job. My one and only DIY liner install looks 10 times better than that.
    Did they suck the liner down with a vacuum before adding water?
    Sorry to be negative but the crews skills seem not to match up to the job (or they just went too fast on both the troweling and the install).
    Oct 2013
    wantagh/NY
    14
    Yes the liner was sucked down with 2 vacuums. I think they just did a bad job smoothing out the floor aside from the wrinkles and misalignment in the corner's we also have boot print's on the floor. Do you think it's worth making a big deal about or should we just let it go? Thanks to everyone for their help
    Oct 2013
    wantagh/NY
    14
    Tried a few night shot's, the brush in pic's is 3' long. Thanks
    Feb 2012
    Maryland
    400
    Yes its worth making a stink over it. I too DIY's my liner install AND my vermiculite and it looks a million times better than that. Seeing work like this makes me happy I did DIY and was one of the reasons I did. I think lots of labor simply wants to get in and out quick. I am sure there are good places out there, but work like yours give them a bad name.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Oct 2013
    7
    Make a stink, if you haven't already. My guess is installer vs liner. Sand bottom requires more assistance at the time of liner drop. It must be dropped in or laid in and carefully unfolded. If dragged in it will give you little ridge rolls of sand under the liner and scrap marks from the seams. Also, sucking the liner in with a vac before putting in water will tell a good installer if the liner is fitting properly or needs to be adjusted before a drop of water hits the vinyl.
    Oct 2013
    wantagh/NY
    14
    Funny you replied today. They came over a week after I posted this and was told that's as good as it get's and pretty much to go F myself. Since then I had 2 other installer's come over and take a look thinking I would end up in court. After calling them this morning with the results from the other companies they came over within the hour and agreed to remove the liner in the shallow end and redo the bottom in the spring. And YES I have it in writing. Thanks to everyone for the help
    22,544
    Glad it's going to get worked out. I'd make sure to be there when they redo the installation even if I had to take a few days off in order to be there. Just to let them know I was watching.
    Oct 2013
    7
    Glad to hear they are working towards resolution. I agree that you should be there.
