Thread: Update on Troublesome Pool
    At the beginning of the season, I was having a great deal of trouble with equipment and getting the pool chemistry right.
    Following the advice given by other list members, using a proper test kit, following basic guidelines in pool school, and dosing per the very helpful pool calculator "app" I have had great success. With a little patience the floating layer of scum resolved, the CYA levels dropped to manageable levels, and the pH came up to normal levels. With the addition of about 1gallon of 8.5 bleach every week, I keep my FC levels between 4-6; crystal clear water, no algae. So that's less than $3 per week. It is also key to have a properly operating skimmer which greatly reduces the amount of work.
    So the reason for this post is primarily to say THANKS, and also to give my endorsement to this system and encouragement to anyone having frustration with their pool.
    Sacramento CA
    33,000gal, IG, circa 1970, (now) fiberglass over plaster, pac-fab paper cartridge, 1.5hp pump, polaris 280 (inoperable, UV damage) with booster, solar heat (inoperable, leak in powermat), skimmer (inoperable, line clogged & possibly fractured under concrete), main drain inoperable (long standing problem), jury rigged deep intake, skimmer line work-around in progress.
    38,521
    Re: Update on Troublesome Pool
    Congratulation on taking control
    We love hearing these success stories
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes we do. Way to go Conrad, it only gets easier from here. Glad you are enjoying the forum. Welcome to TFP!
    Essential Links:
