Results 1 to 13 of 13
Thread: New build in So. Cal - update w/ time lapse video...
    Sep 2013
    Simi Valley, CA
    73
    So we're finally starting the process of building a pool (again...)... Got the HOA approval and are now waiting on city to issue permits... if all goes well, we should start digging within 2 weeks or so...
    Specs:
    Area: 804sf
    Perimeter: 120f
    Depth: 3.5' - 6.5'
    Volume: Guestimating it to be about 25-27K gallons...
    Plaster: Color (haven't decided on the actual color yet but leaning towards gray-blue mix)
    Coping: Flagstone
    Bond beam: 12" faced w/ flagstone
    Deck: Color Stamped concrete
    Water features: 3 24" sheer descents on bond beam
    SPA: 10'x7' 8-jet @ water level (will probably do infinity edge-like finish so that the spa wall is almost level w/ water surface)
    Waterline tile
    Skimmer: 2 on separate piping
    Lights: 2 pool, 1 spa (not doing LED)
    SWG: Jandy AP-1400
    Filter: Jandy 580sf
    Pumps: Jandy 1.5 HP for sheers, Jandy 1 HP 2-speed for filter / circulation, Pentair 3HP intelliflow for spa jets
    Heater: Jandy 400LXI cupronickel
    Automation: Jandy 6614AP-L power center w/ RS8 P&S & iAqualink
    Plumbing: 2.5" suction w/ 2" return for pool, 3" suction w/ 2.5" return for spa jets
    auto fill
    Here's a pretty basic plot plan for what we want (not completely accurate -- decking goes all the way to property line on left, not showing all lights/skimmers)
    [attachment=0:18ld7wi2]plot plan.png[/attachment:18ld7wi2]
    We get a lot of wind from left to right during certain times of the year, so we're definitely going to need a skimmer in the right corner, would love some suggestions on placement of the other skimmer...
    The first light, is going where it's shown, now we need find a place for the second light.
    Would love to hear feedback, suggestions, criticisms (not too many of those, unless really warranted )
    28K IGP, AquaPure 1400 SWG, Inteliflow filtration, Inteliflow spa, pentair 1.5HP water feature pumps, pentair cartridge filter, 2.5 / 3" plumbing.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: New build in So. Cal
    That quote is amazing...it matches pretty much all our usual recommendations: big filter, properly sized pumps, properly sized pipe...wow! It leaves some stuff out though...how many returns in the pool? At least 3 or 4 is good. How are you planning to clean it? Manual vacuum, automatic cleaner?
    Have you thought about what you'll use the deeper area for? 6.5' is too deep to stand, but too shallow to really safely dive. Most are either 5.5-ish or 8-ish deep for those reasons.
    Sep 2013
    Simi Valley, CA
    73
    The quote is that way because this is what I asked for, mainly due to the great advice I've gotten here...
    The pool will have 4 returns.
    There's a vacuum line & vacuum
    The depend is more for just 'playing' around... don't want any diving, just deep enough for this that want to do some 'snorkeling'...
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Quick question from pool noob... Why a separate pump for circulation and filtering, when the intelliflo can handle that along with the spa function? Since you can't run the circulation while the spa is running (assuming you have a spillover into the pool), I don't see the need to run the separate pumps.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Oct 2009
    3,899
    I can't speak to Gary's specific setup, but usually you'd have a separate jet pump on a separate plumbing loop, so that it doesn't have to go through the filter. All it does is pull from the spa and push from the jets...no filtration, heating, etc. In spa mode, the circulation pump would pull from a different drain and go to different returns, while being filtered/heated.
    Sep 2013
    Simi Valley, CA
    73
    Killer95Stang, there are actually a few reasons... first of all, is I have 8 jets and in order to get somewhat strong jets, I need 15GPM per jet... that's 120GPM... Most "big" pump can handle this, w/ 0 head, but there's always head, so I oversized a little both on pipe & pump. plus this will give me control over jet strength. Plumbing it this way also allows me to bypass filter/heater, thus reducing head & prolonging equipment life.
    The circulation spa will still run while the jets are on, either warming/filtering the spa, or filtering the pool, either is technically an option... I could switch heat off in spa, turn it on in pool, or vice versa... basically, my jets have nothing to do w/ which body of water I'm heating/filtering...
    Sep 2013
    Simi Valley, CA
    73
    A few updates... got our permits, ran the utilities to where the equipment pad will be, and decided to switch all equipment to Pentair because Pentair heater is significantly smaller and we have very limited room at the eq pad... automation & swg will stay jandy.
    The dig begins in the morning!!! Got the camera sitting on tripod waiting to do some time lapse shooting...
    Oct 2009
    3,899
    woo! Time lapses are really cool...
    Sep 2013
    Simi Valley, CA
    73
    Half way through day 1... grading almost done...
    [youtube:38p538pi]6dJg_wkF_ew[/youtube:38p538pi]
    Sep 2013
    Simi Valley, CA
    73
    Actual dig - day 1 of probably 3...
    [youtube:59jjj27i]7Cz7phJDPgs[/youtube:59jjj27i]
    mcanchola2's Avatar
    Apr 2013
    San Tan Valley, AZ
    64
    Re: New build in So. Cal - update w/ time lapse video...
    was the ground pretty hard? I see they brought out the jackhammer attachment.
    17k IG pool (34' X 19'), Pebble Plus Interior - Artic, Hayward ECO Star Variable Speed Pump, Hayward ProLogic P-4, Hayward 480 Cartridge Filter,
    (2) Jandy Deck Jet's and (1) bubbler, Wave Force Cleaning System, Trident UV sanitation System, TF-100 test kit with SpeedStir
    My Pool Build
    Sep 2013
    Simi Valley, CA
    73
    Yeah, the first 2-3' were hard as a rock. Soil around here is pretty bad, guess that's what you get in a 'desert'
    Sep 2013
    Simi Valley, CA
    73
    The steel is in!
    [youtube:1j0faoav]etqZtXBgPcU[/youtube:1j0faoav]
    [youtube:1j0faoav]wtrK4IY0eE8[/youtube:1j0faoav]
