Results 1 to 10 of 10
Thread: CSI
    May 2013
    Cyprus
    159
    CSI
    Hi
    I run my pool for 2 Hrs in the morning and my pool is clean. A pool expert told me today that I should run my pool for a min of 6 Hrs, if not my CSI would go through the roof. My tests are within the limits as using the pool calculator. Is what this expert said true.
    FC 7.4
    TC 7.2
    pH 7.4
    TA not tested run out of tablets
    CYA 73
    I dosed the pool with 0.5 Lts chlorine after the test.
    I will be changing my water to bring the CYA down.
    Living in Cyprus
    Still enjoying life
    22,553
    Re: CSI
    The length of time the pump runs has nothing to do with the CSI.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: CSI
    Quote Originally Posted by bof
    Given that this is working for you, I would stick with it.
    There are so many opinions out there on this subject but, at the end of the day, what matters is that your water is clear and your chemicals are within the recommended ranges.
    FYI, here is the process I followed in helping me Determine the Pump Run Time. It quickly dispelled the pump run time "urban legends" that I had been previously told and saved me a lot of loot on the electric bill.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: CSI
    This statement proves that this person is not a pool expert.
    May 2013
    Cyprus
    159
    Re: CSI
    Ah but the "pool expert" has certificates lol
    Living in Cyprus
    Still enjoying life
    38,508
    Re: CSI
    You did not post enough test results to calculate the CSI. What kit do you use?
    May 2013
    Cyprus
    159
    Re: CSI
    Hi jblizzle
    I use a scuba 2 from lovibond the water temp was 21 oC and the TA as tested last Tuesday was 100 ppm. What the expert said was that the CSI would esculate if I did not run the pool for 6 hrs. a day. I have been running the pool on a trial bases for just two hours as the pool is not used very much at the moment and will get used even less as the temp. drops.
    Living in Cyprus
    Still enjoying life
    38,508
    Re: CSI
    A key to the CSI is the calcium hardness which you have yet to report.
    In any case, the CSI is a function of the chemistry which has NOTHING to do with the pump run time. Sounds to me that the term "expert" is being VERY generous.
    In the winter months, it is very likely that only 2 hours is plenty of run time. As the link that was given above shows, you really just need to run your pool long enough for it to stay clean enough looking to you ... assuming you keep the chemistry managed.
    May 2013
    Cyprus
    159
    Re: CSI
    Sorry the CH is 500, the water on the island is supplied from wells and the CH is the same throughout. We are not allowed to use piped water to fill the pool we must get it tanked in.
    Living in Cyprus
    Still enjoying life
    May 2013
    Cyprus
    159
    Re: CSI
    Thanks everybody I hade read the run time blog and used that as my base line. It is just that when a pool expert tells you something I like to check it out, but yes you all were right again and the expert was a generous title.
    Living in Cyprus
    Still enjoying life
