Thread: Quick question about Water Features
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Dumb question incoming!
    I've read a few times that "aerating" increases PH level. I've also read that aerating reduces the pool water temperature.
    So, how do you stop the PH from increasing beyond acceptable levels and still use your water features overnight to reduce water temps?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Re: Quick question about Water Features
    Quote Originally Posted by zethacat
    Most of the time I guess you use more acid. You also then need to add to your TA over time. Perhaps you add Borates for a more stable pH?
    Jun 2013
    Newcastle, Oklahoma
    508
    i ran our waterfall fountain nearly every day for several hours to cool pool during the day when water temp would go over 86, plus for an hour or so many evenings since kids love playing in it. it went 6-8 feet high too. pH fluctuated between 7.6 and 7.8 and never went above 7.8 no matter how much I ran it. since I have a vinyl pool, I didnt do anything to lower it, just left it be since a slightly higher pH in a vinyl pool isnt that big of deal. My TA was 100 though, so that may be why my pH didnt just go nuts.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You really can't stop the pH from increasing, but you can maintain it by adding acid to lower it. Just stay on top of it and you'll be OK. You are correct about the water features doing those things.
    Essential Links:
