Thread: Above ground winter pool cover
    Jun 2013
    Michigan
    24
    Good morning!
    Should a winter pool cover be tight (relatively) across the top of the pool when its closed? I live in Michigan and we get lot's of snow. I have a larger cover on it (about an extra 10 inches at least) and the "extra" length is laying inside the pool on the water line. I'm not using a pillow.
    I think-We should get a pump to use over the winter, get the pillow, AND make the cover a little tighter across the top instead of it resting on the water.
    St. Clair MI, 18,600 AG, Sand, Hayward Pro Series, Top-Mount, Model #S210T93S, 1+1/2-Horsepower Matrix Pump. Installed June-2013.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Re: Above ground winter pool cover
    I agree withe the pillow (or two) as might be required. Rain runs off before it freezes. Frozen stuff has an opportunity to thaw and run off.
