Thread: CHANGE PUSH/PULL TO MULTIPORT BACKWASH VALVE
    gbski's Avatar
    Sep 2013
    Central Florida
    22
    Can I replace a multiport backflush where I have a push/pull on the same filter? I have a 36 SF grid DE filter with the push/pull valve which is currently all jambed up. Would like the vacuum to waste feature possibly.
    Thanks!
    Thanks!
    gbski
    13,000 gal. IG 1994 pebbletec, 1.5 hp pump, 36 SF DE grid filter, Pool unscreened, The Pool Cleaner (suction), on well water
    Re: CHANGE PUSH/PULL TO MULTIPORT BACKWASH VALVE
    You should be able to do that. What filter (make, model) do you have?
    Support the site
    gbski's Avatar
    Sep 2013
    Central Florida
    22
    Mfr is Andrew's Advantage. Probably circa 1994 when pool built. Not sure if there is a model # - dark in there... Thanks
    Thanks!
    gbski
    gbski's Avatar
    Sep 2013
    Central Florida
    22
    Tried to take out the piston to replace O-rings. Could not get the dang this out no matter. So I'm back to looking at replacing the whole backflush valve and the MPV again... The filter model # wore off the tag. The push-pull valve label is a Pentair 26-1165. Can I put a Pentair 26-1055 MPV in as a replacement. I have the 7.5" center and 2" pipe connections.
    Gbski
    Thanks!
    gbski
    30,419
    Any MPV should fit if it's 2" ports and 7.5 on center. (mine is a Pentair MS 203 and has those dimensions)
    You will surely have to re-plumb the intake (from the pump) and output (to the returns) plumbing.....I don't think you can match those up switching from a push-pull to an MPV
