Results 1 to 7 of 7
Thread: Pump is "talking louder"
    Okay so I notice a much louder noise in my back yard and walk around the corner to hear that it is my pump. I can hear the bearing squeak at certain times and the motor itself has a noticeable increase in noise. The original pump was a hayward and was replaced with Century Centurion (A.O.SMITH). The pump appears to be about 3 years old and is a 1.5HP pump.
    I'm looking to see what I need to do as I'm not sure I can continue to run it (without damage to other equipment) or stop to repair\replace it. I just replaced my liner last week so it's been a pretty expensive month for a pool that is hardly getting used at the moment.
    Looking for recommendations on how to proceed to address my latest adventure.
    Thanks
    27K Vinyl IG Pool
    18x36, Aquarite with Goldline T-15 SWG,
    Hayward 244T Sand Filter, 1.5 HP Hayward Super Pump w/ AO Smith B129 Motor
    Taylor 2006 Test Kit
    NW Louisiana
    Ellington, CT
    262
    Re: Pump is "talking louder"
    Replace the bearing yourself. I did it.
    https://www.youtube.com/watch?v=5R4yhrvSKcg
    All you need is a bearing puller which you can get off ebay for around ~$15 to $20. Bearing are also available on ebay
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Is it going to hurt to run it until I can get the bearing in? It just happened last night. It's priming (no bubbles) good and pumping water with no visible issues.
    additionally, is that website a reputable place to purchase the kits (assuming I need the bearings and shafts).
    Thanks
    27K Vinyl IG Pool
    NW Louisiana
    Smykowski's Avatar
    Sep 2011
    3,065
    Probably not. I ran a screaming pump for 6 weeks so I could wait until after the close to repair it.
    Is there a recommended place to purchase?
    27K Vinyl IG Pool
    NW Louisiana
    Smykowski's Avatar
    Sep 2011
    3,065
    Any bearing puller will work. Try ebay, Harbor Freight, or any hardware/autoparts store.
    As for the bearings themselves, you can use either an online pool supply store or if you have a Grainger close, you can match the number stamped on the seal and buy them from Grainger.
    okay, I bought a kit from an online retailer that also comes with the shaft seal. I hope that's all I need and that my pump holds up until it gets here.
    27K Vinyl IG Pool
    NW Louisiana
