Thread: Repair torn seam in Ultra Frame pool
    May 2013
    Littleton, NH
    22
    So I was in the process of taking our intex ultra frame down for the winter. I drained the water and washed down the inside, just needed to pump or scoop out the remaining water and take down the frame and liner. But alas, I was out of time and had to work today. Well, we just had a pretty nasty rain and wind storm and it made a pretzel out of our 18' pool that I just bought this year and spent all kinds of time setting up!
    It's a little dark out so didn't get a great look but looks like some of the frame pieces are ruined, I assume I can buy replacements. BUT, the big thing is that one of the spots at the top that the tube goes through the liner to support the liner (if you know what I mean) is torn so that there's no loop anymore (or tunnel if you will) I wondered if I could patch/weld a piece of vinyl to hold the two together somehow? Or am I just out $400 ???
    Intex 18' X 48" Hard Plumbed running the 1800gph pump that came with it. Using BBB method
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Repair torn seam in Ultra Frame pool
    I wouldn't trust a patch weld in a seam anywhere on one of those. Sorry, but I'm just not sure you could trust it.
    Essential Links:
