Results 1 to 7 of 7
Thread: Pool spots and spa overflow question
    Feb 2013
    Venice, FL
    23
    This is a 2 question post.
    First question is about the spots my pool has, they have been there since I bought the house in January 2013. The previous owner said the spots showed up right away when they built the pool in 2005. I will try to post photos from January showing what they looked like at the start. I have done 2 doses of Jack's magic blue stuff, the spots lightened. Wondering if anyone knew what they might be. They look to be green and deep into the plaster. The spots were bad enough in the spa I could use a toothbrush on them and the spa would end up being green. I have heard it may be copper from my heat exchanger or algae embed in the plaster? I could believe either. The spots have only gotten better all year after I finally got control of the chemicals after reading the stuff on here.
    Second question, the white plastic overflow pieces are becoming loose from the spa overflow. What options do I have in replacing them? I think these look cheap and the white color is not flattering. We really wish they wouldn't have used the brick color coping around the pool when they built it, but thats neither here nor there. Is there a catalog/book that sells this type of stuff?
    Hopefully I can get the pictures to load
    Thanks
    IG Plaster~8500gal pool, ~300gal spa, Cartridge filter, ComPool LX100 controller, PentAir 320 In-Line Chlorinator, SwimTemp heat pump
    38,284
    Re: Pool spots and spa overflow question
    Try rubbing a trichlor puck on the spots ... if they lighten/disappear then they are organic/algae stains. If not, put a sock of crushed up vitamin C tablets on a spot for a few minutes ... if they lighten/disappear then they are metal stains. Once ID'ed we can advise treatment.
    As far as the spillover, I would suggest removing the plastic and getting some matching tile and grout instead. Most overflows I have seen just use the same tile as around the pool. Of course this kind of depends on what is behind the plastic.
    Feb 2013
    Venice, FL
    23
    Thanks, I will try the stains after work today and let you know.
    I have to take the plastic off anyways, it has started to get loose from the spa. Figured I'd mess with it when it gets to winter, in case the pool is down for some time. In a perfect world, while I have it apart I'd like to make the spill-over wider.
    Feb 2013
    Venice, FL
    23
    The green parts of the stains were taken care of with the vitamin C tablet... There is still a spot left, but I think that may have been the original color of the plaster and the rest has faded? I have a few very black spots on the pool bottom. The vitamin c tablet erased those quickly.
    What would be my next steps?
    Thanks !
    Feb 2013
    Venice, FL
    23
    My PH has been in the 7.6-7.8 range fairly often recently. Would it be safe to assume if I keep my PH in the 7.2-7.4 range the spots should not get worse, and may actually lighten some of the stains if they are copper? I will be getting some AA to follow the process I found in the forums. I think my spots may be more of a copper base as the halo around some of the spots are a blue/green.
    I will be more diligent about getting and keeping my PH lower as I now somewhat understand the relation of that and possible staining issues. Does anyone have a recommendation of a metal sequesterant to use while doing the AA treatment, and for maintenance doses? I would also like to keep my budget in mind, since I will have to add this weekly?
    Thanks for all the good reading.
    38,284
    The metals article in Pool School lists the types of sequestering agent we recommend. I have no experience and can not remember offhand.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Quote Originally Posted by hybridtrendz
    What you should do is the portion that the water overflows on, replace the plastic with any color of marble like you find in your house for the window ledges. Seeing you're in Fl you probably have those type of sills in your house.
    As for the metal staining, you need to determine where it's coming from. You show in your signature that you have a heat pump. You don't have a gas pool heater for the spa? If you do, then it sounds like the copper in the heat exchanger is being eroded into your water. Make sure to balance your chemicals correctly and as you mentioned, keep your PH in balance.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
