Thread: Benifit of an in-floor circulation system ??
    I am confused as to the benifit of an in-floor circulation system, not the full in-floor cleaning system, but a series of 6 returns that distribute the return water through the floor. Is it that much better than the standard 4 returns on the sides of the pool ?
    THANKS for any input.
    Mar 2008
    Los Angeles, Ca
    222
    Re: Benifit of an in-floor circulation system ??
    My pool was built long ago with an in floor cleaning system, but at some point (before I owned it), the motor broke.
    I looked for parts a while ago, but it is so old I could not find anything that looked compatible with my system.
    Bottom line is that I now have 6 returns on the floor, although only three have water flowing through them. If my system was working, then it would rotate the returns.
    I really don't see any advantage to have the returns in the floor, versus the side walls. In my pool, with the floor returns sending water out parallel to the floor, it does cause the dirt to accumulate in certain places.
    Randy
    25,000 gal fiberglass pool, Raypak 200k BTU H200FDN gas heater, Pentair CCP520 520 sq ft Cart filter, Max-Flo VS2303VSP pump. iWave wireless remote,
    seperate spa, with own pump, cartridge filter, Hayward H200FDN heater
    Could the same heating benifts being sold by this system be created by lowering the placement of the sidewall returns that are standard with the pool build ?
    i.e. 1.5 feet from the floor ?
    thoughts
    Mar 2008
    Los Angeles, Ca
    222
    Quote Originally Posted by arizonaheat
    thoughts
    What are the benfits supposed to be for an in floor circulation system?
    It is my understanding that it assists with Chemical distribution, assists with keeping the pool clean by providing more even water flow on floor and eliminating dead spots, AND distributes the heated water more efficiently by pushing it through the floor rather than the top.
    Is this all sound reasonable ?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Arizonaheat, welcome to TFP! I've spoken on this in the past and you've got the right idea I'm a little dubious about keeping the floor cleaner, but you get better heating by adding the heated water at the bottom (heat RISES)
    Because we install only liner pools, we have a 'heater zone' which consists of 3 regular returns ~ 14" up from the bottom of the panels to provide a similar effect. (though they make them, floor returns in a liner pool are a BAD idea IMO)
    However, you still need regular returns near the surface to create the circulation that allows the skimmer (s) to do it's job and prevent stuff from ever sinking to the floor!
    Luv& Luk
    -Ted
