Thread: Calling all Aqua Genie Owners
    Hello all
    First time pool owner - so be gentle
    With Fall/Winter here I am looking at closing the pool
    I have read the section on pool closing and understand the basics of chemicals/antifreeze and such. I understand I should blow out the lines from the filter to the pool. The question I have is - I have an Aqua Genie and I understand I would lower the water level to below the return to allow for proper blow out of the return line. Do I need to get the winter cover/door Aqua Genie sells? I seem to be getting conflicting information - I know the Aqua Genie needs to have the water below the unit, but I also hear I should try and keep the pool water as high as possible? ( I have a Buster Crabbe pool - vinyl with wood walls)
    Any pointers or advice would be much appreciated.
    Thanks
    Sep 2013
    Auburn, Alabama
    73
    Re: Calling all Aqua Genie Owners
    Where abouts are you located?
    If in the south I would say you do not need the cover.
    If in a colder climate you may very well need it.
    Aqua Genies can develop cracks inside the return box that are very difficult to find.
    The Original Leak Specialists.
