Results 1 to 8 of 8
Thread: which seal kit for hayward RS1500?
    So, I have a little leak on the pump side of my motor mounting plate. I figure i better get it fixed before the problem multiplies... I cant seem to find much info on the hayward RS1500 pump. I found a .pdf schematic and tried to cross reference some of the parts on it to the part numbers in the go kits. From what i can tell i need the GO-KIT3 can anyone confirm? I found this kit for like $21 shipped. Is that an OK price? if not where is a good place to buy pool parts?
    Thanks
    ~25k gallon IG plaster, Hayward RS1500 pump, Tagelus 60D sand filter, Taylor 2006 Test kit.
    38,537
    Re: which seal kit for hayward RS1500?
    The RS line of Hayward pumps I think are only sold by Leslie's pools. Effectively it is the same as the the Super pump line, but I am not sure if all the seals are the identical. Certainly Leslie's should have what you need, not sure the price, but might be worth a recon mission
    The parts match the Hayward Super II. That would match the Go Kit 2.
    http://www.poolsupplyworld.com/Aladdin- ... KIT2-9.htm
    http://www.hayward-pool.com/pdf/Parts%2 ... per-II.pdf
    Support the site
    Thanks guys,
    I'll start with a go kit 2. If the seals don't match up I may have to head over to Leslie's
    All of the part numbers are the same, so it should work. There is a part listed as "Support Base O-Ring", which I think is the lid gasket. I don't know why they call it a "Support Base O-Ring". Perhaps it's the same gasket as used in another piece of equipment, and that is what it is called for that piece of equipment.
    Support the site
    Thanks everyone!!
    I ordered the Go-kit2 yesterday, probably get around to installing it this weekend. Ill report back when i install.
    Thanks
    Go kit 2 worked great. All seals fit perfectly.
    Thanks for the update.
    Support the site
