Results 1 to 12 of 12
Thread: Pump Offset
    Oct 2013
    Houston, TX
    32
    Pump Offset
    Ok, A new venture for me. Since the pump housing(diffuser?) was cracked so I called a pool company. They did not return my call. So I purchased a new housing. I cut the line to four way valve and am trying to re-install the pump. As it stands the pump housing is about 1/2 inch away from the strainer and 1/2 inch lower and half inch to the right. Can I force everything together and bolt up the pump or am I asking for trouble by putting too much strain on something (pipe, pump, four way valve, strainer)? Is it time for me to give up and call a professional? Thanks.
    Andy49
    12K, IG, Plaster, DE, Install 1992, Spa, Polaris Sport, Rainbow Chlorinator 320, Taylor 2006
    38,371
    Re: Pump Offset
    Welcome to TFP!
    I am having a bit of trouble understanding what you are describing, maybe due to different terminology. Can you post up a few pictures of the issue?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump Offset
    Welcome to tfp, Andy49
    I agree with jbliz, a picture would help us understand.
    Oct 2013
    Houston, TX
    32
    Re: Pump Offset
    You are correct. I will take a few pictures and post them. The original size of the picture file will be 5 mob each. Do I need to somehow reduce the pic size or does the forum software reduces the size automatically?
    Andy49
    38,371
    Re: Pump Offset
    You need to reduce them, or link to them on a different hosting site.
    Oct 2013
    Houston, TX
    32
    Re: Pump Offset
    Here is one pic that shows the gap between the pump housing and the basket strainer.[attachment=0:12rt1swn]Offset.JPG[/attachment:12rt1swn]
    Andy49
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump Offset
    Is there enough "flex" in the system to even line them up? If there is, and you can get it so the whole oring seal is under compression, it might work. I doubt it will hurt the pump unless you have to tighten it so much that you crack the pump housing or basket. I would carefully try it and then put some water in and see if you have leaks.
    Oct 2013
    Houston, TX
    32
    Re: Pump Offset
    I am concerned because,
    1 I have to pull the pump against the strainer basket
    2 I have to move the pump to the left
    3 I have to raise the pump
    If I do all three, only then the pump is aligned with the strainer basket.
    Andy49
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump Offset
    Number 1 above should be fine imo, if it is not too much force on the fasteners (bolts in tension). 3 above might be fine, I would definitely support the pump from below so the weight is on that, and not just on the connection. Number 2 and 3 above have me a little worried, unless it does not take much force to do it.
    One thought, if it is the same pump housing (dimensionally) as before, maybe this is why it cracked?
    Oct 2013
    Houston, TX
    32
    Re: Pump Offset
    The old pump housing was about 15 years old so I was not surprised that eventually it cracked. I have additional pictures that may show the piping/pump arrangement more clearly.
    Andy49
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump Offset
    Use a hair dryer on the short section of pipe between the multi-port and the 90 until it heats up enough to bring the two pieces together. Because that pipe is far away from the pump, less movement is needed. But don't get the heat too close to the multi-port valve or the glue joints.
    Mark
    Oct 2013
    Houston, TX
    32
    Re: Pump Offset
    Thanks for the suggestions. I just gave up and called a professional. He will be here in the morning. I just hope that the fees are reasonable since I have retired a while back. I am happy that I found this forum. Very helpful and nice community.
    Andy49
