Thread: Landscape Lights and Hayward ProLogic 16v
    I've been looking at LED lights for my pool area lighting. All need a transformer? Maybe I'm not following this correctly.
    So, is there any setup that would allow the ProLogic direct control, ON/OFF and dim, of landscaping lights without going through a separate box?
    Carl
    Apr 2013
    Sacramento, CA
    2,769
    Re: Landscape Lights and Hayward ProLogic 16v
    Generally you need your controller (ProLogic in this case) to go to a motor relay which controls the lights.
    See the links below, but I must warn you if you are price sensitive you may end up in the hospital.
    http://www.fxl.com/introducing-luxor
    Look here for another article:
    http://www.lutron.com/en-US/resourcelibrary/362219.pdf
