Results 1 to 10 of 10
Thread: Pretty good water chemistry
    Sep 2013
    Carrollton, TX
    58
    After my total water replacement I have continued to adjust the water chemistry.
    Right now my concern is a fairly sudden onset of reduced water clarity compared to when the water was new a few weeks ago. Have kept the FC at 3 or better.
    OCLT is .5 ppm and will check tonight again. Cartridge filter exhaustively cleaned yesterday with an 8 hour pump run...2 four hour runs 12 hours apart.
    Today, 3 pm central numbers:
    FC 7.5
    CC 0
    TC 7.5
    TA 60
    CH 140
    CYA 40
    pH 7.2
    Suggestions? More circulation time? Still do have a leak but seems isolated to suction retun and when the vacuum hose adapter is installed the leak is greatly reduced....so can leave it installed to help that situation...
    IG Gunite | 90' circumference (sort of oval), 8' Diving pool | ~16,300 gals | Challenger Pump | American Cart 200 Filter | Zodiac G4 Baracuda
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pretty good water chemistry
    I would bump the run time by a couple hours and keep the FC a little higher (10ish?) for a few days. See if that clears it up.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Your CH needs to come up to at least 250 ppm for a plaster pool. 3 is the bottom of your recommended FC range, if it could have dropped below that for a day or two you may be on the edge of an algae bloom. Try bringing the pool to shock level for 24 hours and run the OCLT again.
    Love TFP? Become a
    TFP Supporter!
    Sep 2013
    Carrollton, TX
    58
    Quote Originally Posted by zea3
    Checking all these numbers....this shows my min/max/shock level for 40 CYA:
    CYA (Stabilizer):40 Minimum FC:3 Target FC:5 Shock FC:16
    Pool Calculator shows this for current #s and conditions, to raise CH (sanity check):
    CH current 140
    Goal: 250
    Add 265 oz by weight or 212 oz by volume of calcium chloride
    or add 352 oz by weight or 404 oz by volume of calcium chloride dihydrate.
    Pool Calc shows -.78 and if I reach these numbers it calculates to -.32 (in the acceptable range if I'm reading this right, as compared to -.78 which is beyond the -.6 acceptable for plaster pools).
    RIGHT? - that sure seems like a lot of calcium chloride!
    TA of 60, raise to 100 (?) by adding 153 oz by weight or 122 oz by volume of baking soda
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I'd leave the TA alone, assuming your pH is stable. If not, at most, start with 70ppm TA and see where that puts your pH long term.
    It's so easy to raise, but a lot of work and time to lower. So go easy on it.
    Did you measure your CH /w a speed stir?
    Definitely do an OCLT at full shock levels, too little CL to play with otherwise.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    38,284
    Play with the pH in the calculator. If you raised that a bit, that will have a pretty substantial impact on the CSI.
    I left my CH low after a refill and kept the pH a little higher to compensate ... knowing that in AZ, the CH will rise due to evaporation so I did not want to intentionally add CH.
    Edit: although if you need to SLAM, don't raise the pH first. And I too would not raise the TA much of at all.
    Sep 2013
    Carrollton, TX
    58
    I don't yet have a speed stir but I have repeated the test a few times close together so I have good confidence with the #s and my swirl method is pretty much like it was in chem lab by hand, back in the day.
    I'm in the SLAM mode and will do the OCLT overnight, after a long pump run until the wee hours, and see how it shakes.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Just to clarify, when you do an OCLT, leave the pump running between the 2 tests, after dark and before dawn.
    In order to get an accurate indication of consumption by any organics that may be present in the water, continuous circulation is critical.
    Sep 2013
    Carrollton, TX
    58
    FC last night was 15 ppm; CC .5 ppm, TC 15.5.
    This morning, FC was 14 ppm; CC was 0, and TC was therefore 14 ppm.
    The water looks somewhat better. Pump ran all night.
    I am going to re-test tonight as well.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    It sounds like you're riiiight on the edge, something was beginning to grow in the water.
    As technically you passed the OCLT, but if the water clarity improved, you're surely killing off the beginnings of a minor algae bloom. That point where the water still looks more or less OK, but it's beginning to "dull" a little.
    Keep SLAMing it, keep FC up by staying on top of those CL additions. It's OK to add a little more than an FC of 16ppm to compensate for UV loss, outgassing and consumption by organics present in the water. But more, is not better, as you'll lose it waaayyyy too fast if you go too much above FC 16.
    Also, keep in mind that you will lose more CL during the day due to UV exposure, as it burns off the CL some, even with the CYA in there, which only slows the process, it doesn't stop it.
    Keep on it in the daytime, so you don't dip below an FC of 16, as much as possible. Then plan your attack time for evening, when the sun goes down, as without the UV present, the CL has more of a chance to work and be more effective, since it stays longer and has more "killing power" if you will.
    Not that CL can't kill algae during the daytime, it's just that as the CL is busy killing "oxidizing" algae and other organics, it's also being broken down by the sun's UV rays. See? Yeah... CRAZY!!
    When you do an OCLT, you want your FC @ 16, not 15ppm. But it's still a good indicator that you need to keep SLAMing that puppy!!!
    SLAM it until it sparkles, sparkles as much, or more than tap water.
