Thread: Draining AGP, last little bit of water little green
    Jun 2012
    Michigan
    154
    I have a 16x48 intex AGP that i'm draining, the water is almost below the level of the drain plug thing, so i have that water to still drain somehow still. As it's taken days to drain, that water at the bottom has gotten a little brown/green, guessing from leaves and maybe algae? Is there something i should put in this low level of water to kill the green or would it be best to wait till i get it completely drained then do something?
    I dont have a pool store nearby but could run to a store and get bleach or something common.
    Intex 16x48 UltraFrame AGP, included filter pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Draining AGP, last little bit of water little green
    You can use a leaf net to scoop out any debris that may be in the pool, then after it drains wipe it down with a mild bleach and water solution and let it dry before putting it away for the winter.
    Love TFP? Become a
    TFP Supporter!
    Jun 2012
    Michigan
    154
    Ok thanks. would it be of any brnefit if I'd dump some bleach in there now?
    Jul 2009
    Houston, Texas
    9,379
    You would have to mix it in manually. Plus you would have dead algae on the bottom that would need to be cleaned out. How deep is the water that is left, more than a couple of inches?
    Love TFP? Become a
    TFP Supporter!
    Jun 2012
    Michigan
    154
    it's probably a couple inches. I guess less than 6
