Thread: Will this check valve work with acid
    May 2013
    Dallas area
    85
    Will this check valve work with a low pressure stenner pump plumb into the return side of the system with acid?
    Thank you,
    Anthony
    http://www.lowes.com/pd_103896-33599-P3 ... facetInfo=
    Dallas area, free form, quartz finish, flagstone, pentair cartridge, vs pump, swg
    Jul 2013
    Mesa, Arizona
    86
    Re: Will this check valve work with acid
    The PVC body and the EPDM rubber gasket should be okay, but I'm not so sure about the 304 stainless spring in there holding up.
    Mesa, AZ Spillover spa and inground pool, 12,500 G, pebble finish, Hayward C5030 (525sf) Cartridge Filter, Hayward EcoStar VS Pump, Installed July 2013, Hayward SWG T-Cell-15, Trident UV (I know, I know....was installed before I found this site!) Rock grotto waterfall, LED ColorLogic lighting, 110 BTU Heat Pro Electric Heat Pump, Maytronics Dolphin Supreme M5 cleaner, TF-100 test kit with Speed Stir.
    May 2013
    Dallas area
    85
    I found that muriatic acid is another name for hydrochloride acid. It won't hold up.
    Thank you
