Results 1 to 10 of 10
Thread: Identify PVC union manufacturer?
    I am trying to match up half a union fitting, and have tried a different brand from a few stores and none match up. Diameter of the thread side is different on each. My PB used these. Does anyone recognize the logo? If I knew the manufacturer I could probably track one down.
    Thanks!
    32K gal, gunite, French Gray DB, IntelliFlo VF, IntelliFlo, WhisperFlo, Quad DE 100 filter, IntelliTouch, IC-60 SWG, IntelliChem, Dolphin M5
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Identify PVC union manufacturer?
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Thanks. I just looked all over the Georg Fischer site but could not find any reference to the logo above. I migh ttry to find one to see if it fits. I'd love to find that logo somewhere to confirm.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    "DN" appears to be part of their model numbering system. When I googled all that text on the valve, that's the only hit I got.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Did the GF work? I agree--that isn't their logo.
    I think the "DN50" refers to the valve size, not a part number. I didn't see any promising matches using Google.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Don't waste hours trying to find the right company. Just chop it off and glue a pipe extender if needed an whatever union you want to use. Preferably one with model numbers
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Jun 2013
    SpringHill FL
    415
    I agree just change out the union simple fix.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Clarksville, TN
    126
    Could be "American Pipe" from most Lowes stores. Ironic thing is they're made in China.
    34,000 gal., 20x40 Roman, IG Steel/Vinyl, 500# Hayward Sand Filter, 2HP Ecostar-VS, Savi Note LEDs, Autopilot Digital 220 SWG
    I am not looking to change the unions... I have 4 pumps and 8 unions. I just want the pump side mating half to attach to my blower to blow out the lines easily. I can rig something up, but being able to quickly attach the fitting and blow out the lines will make it very easy.
    I will definitely check out the Lowe's parts.
    Thanks!
    X-PertPool's Avatar
    Exeter, PA
    1,385
    why not just ask your PB? Even if it has to come down to you just buying them from him.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
