Thread: New pool owner questions
    Hi all thanks for any help in advance. Just purchased a home with a built in masonary pool I estimate 30-35k gal. The masonary in the pool is dark. not black or brown, hard to descrobe. The water itsel is very clear. I tried scrubbing sections to no avail. Does it need to be drained and painted? Also I have a heyward DI filter that I believe I will replace in the spring. It is (I believe) about 15 years old and has several minor leaks around the tank and pump. My other question is I have a light tan colored silt on the bottom of the pool is this from the filter?
    Chris
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New pool owner questions
    Welcome to tfp, ChrisInStockton
    Quote Originally Posted by ChrisInStockton
    Maybe post a picture? Are you suggesting that you think it is stained?
    See if you can get some to feel if it is slimy or gritty. If it is slimy then you have algae (it sounds like dead algae). If it is gritty then you have some dirt that needs to be vacuumed. Does it "poof" away when you try and vacuum?
    Yes I believe it's stained.. The tan debris is like silt. It turns to dust when you swipe across it. Is it coming from the filter possibly?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, it sounds like you have dead algae, so it is likely you need to do the SLAM process. See: http://www.troublefreepool.com/pool-...king_your_pool
    Please post a full set of test results, see: http://www.troublefreepool.com/pool-...efore_you_post
    so the staining and the dusty tan stuff are algae related? Thanks. I'll retest everything thoroughly and follow directions on the link.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not sure about the stains, they they could be...but the dusty stuff sure sounds like it might be.
