Thread: Spa cover foam replacement
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Anyone has done this? If Yes where I can get the foam?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Spa cover foam replacement
    I was going to try it but just bought a new cover. Here are two sites that sell the foam. The one will actually laminate it for you with plastic. Some of the covers also have aluminum C channels on the edges. I found a company that also sells those.
    http://univfoam.com/products/styrofoam/ ... and-sheets
    http://www.universalconstructionfoam.co ... ptions.php
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Pysiek's Avatar
    Apr 2012
    419
