Thread: Replace blower with Air-induction jets
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Hello
    Got a used old hot tub for free. QCA EM-100. 240V . Spa came with air blower which sounds like a vacuum cleaner. Is it possible to make it run more quiet? Also is it possible to remove it and use air-induction jets? Anyone ever done that?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Replace blower with Air-induction jets
    I have no idea, but I bet someone has some experience on this.
    Essential Links:
