Thread: Drip edge on waterfall/spillover?
    I have a pool with a hot tub slightly raised from the pool. The spa "spills over" into the pool forming a waterfall. The problem is there is no drip edge so I find a good amount of water clings to the bottom of the spill way and runs down the hot tub siding... the grout in this area slowly being taken away and occasionally I have algae growth in these areas.
    Does anyone have experience remedying this problem? I thought about cutting a small gap on the under side of the spill way limestone but that seems very labor intensive and may not even work depending on how fast the water is flowing.
    Any recommendations?
    10k gal in ground, pebble, 1.5 HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Drip edge on waterfall/spillover?
    If you could post up a picture, you'll get more ideas than if not.
    Essential Links:
    Good idea thank you. The picture below shows the spill over and the edge where the water collections and grows algae.
    Judging from the pictures around here this type of spillover is pretty common. Do others not have this problem? If so, do you know why?
    Is there a better section to post in than this one?
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Can you increase the flow rate? That can help.
    Here's a link to a similar thread with a few suggestions.
    http://www.troublefreepool.com/any-i...pa-t58768.html
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
