Thread: Pool Light will not turn on
    The pool light of my inground gunite pool will not turn on. the light switch is hot but I do not have any juice at the deck junction box.(feeder cable highlighted in red box)
    The light fixture itself is brand new and I tested it to make sure that part works. The deck is about 4 ft wide and
    I am guessing at least six inches thick.
    How is this cable replaced? Do I have to cut through the deck to replace the cable?
    Thank you
    Seanhan's Avatar
    Mar 2013
    Fort Worth Texas
    300
    Re: Pool Light will not turn on
    Man looks like you need a new fixture !!!
    There should be conduit running from behind the fixture to the switch.
    The new fixture comes with a sealed length of wire.
    Sean Hannon
    30,000 Gallons gunite pool Coated by Fibertech
    Hayward Pro Grid 72 / Hayward multiport
    Circupool V3 VS pump
    CirCupool SWG RJ 60, 400.000 btu raypak , Built in SPA
    Jun 2012
    western NY
    1,559
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by grasshopah
    The pool light of my inground gunite pool will not turn on. the light switch is hot but I do have
    I assume you mean you DO NOT have power at the junction box???? If so, a continuity test of the wires using a volt/ohm meter is in order to confirm. Clean out that junction box real well, there may be conduit (should be) feeding that box from the source that the wires could be pulled back thru. If it does not have conduit, tunneling 4' under the deck is not unheard of and is probably a sat afternoon job.
    I'm assuming that in your photo, the wires to the right are from the new luminaire, and the wires to the left are from the switch, correct? If so, you can test the wires coming in from the switch to see if they are broken. Just disconnect the wires at the switch and use an ohmmeter and another length of wire to test each one, or just connect the two together and test for continuity. I would advise replacing both wires if one is broken as whatever damaged it may be affecting the other as well. Besides, you will need the intact wire to pull the new ones in anyway.
    Something to consider is could anything have crushed the conduit? What path does it take and is it possible that something could have been pushed into the conduit, cutting the wire? Try tugging on the wires to see if they move at the other end. If not, the conduit may be crushed somewhere. Wiring doesn't typically stop working somewhere in the middle of the run without some help in the form of a rock, fence post, shovel, etc.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    Based on the replies I went back and cleaned all connections and replaced the switch and prayed... switched the power back on and the light works now!
    Whew! I really did not want to start cutting the deck !!
    Thank you Seanhan, danpik and diyindux
