Thread: Bottom drain on above ground pool
    Oct 2013
    Los Angeles, CA
    87
    Has any one installed a bottom drain on their intex above ground pool. Either on the bottom or on the side torwards the bottom the way racerboy6996 did on his 16 by 32 pool
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    Sep 2013
    Auburn, Alabama
    73
    Re: Bottom drain on above ground pool
    Just throwing this out there.
    The cover over the port in the pool needs to be of the VGB compliant anti hold down variety.
    At minimum only run it with the skimmer fully operational.
    I don't want to seem like a worry wort but I see 3-4 or more drownings in my area every summer, every one has me thinking of the jobs I did in the area and the great people I worked for.
    Please be careful.
    The Original Leak Specialists.
