Results 1 to 8 of 8
Thread: ultra gizzmo
    ultra gizzmo
    pool is a semi in-ground 15x24 oval 54"deep. it's 16" above ground, located in New York. I bought the ultra gizmo because of the blow out hole and i'm looking not to drain the pool if possible. A 1/3 of the ultra gizzmo will stick out of the skimmer, my skimmer is not that deep, can i still use it? will i still have to block off the skimmer with the tupperware where the flap is. this is my first year having the pool. all the research i did, involves draining the pool. still have time, I was in the pool yesterday, but it's time to figure out what to do and i don't want to go near a pool store,nothing but bad advice there.
    7000 Gal vinyl Intex 18 ft x 52" Ultra Frame™ Pool Set w/ Sand Filter Pump & SWG System, BBB
    Then we added: 3 Belgian Malinois, 2 German Shedders, 1 English Russell, plus 2 adults acting like children. (without the p)
    Future Pool: Splash (Dog) Super Pool 21' x 41.5', 27,900 Gal and 40 ft dock jumping ramp.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: ultra gizzmo
    you can still use it, even if you can't put the lid on the skimmer it won't matter.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Re: ultra gizzmo
    do i still have to remove the flapping door and seal that side?
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: ultra gizzmo
    with a gizzmo you don't need to remove anything other than the basket. If you weir (flapping door) is easily removable then you can take it off if you like. If you are using an Aquador (the tupperwear like lid that blocks the skimmer.) then you would not typically need a gizzmo and just remove the plumbing off the skimmer all together. If your plumbing does not come off the skimmer then I would just use a gizzmo by itself and aquador if you happen to have it but it's not needed.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Re: ultra gizzmo
    My plumbing will not come off unless i cut it, Thank you for all your help, it is much appreciated. The only other thing is not being able to put a cover on the skimmer because of the tall gizzmo, allows for all kinds of **** to get in the skimmer during the winter.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: ultra gizzmo
    You can always get some window screen or wire mesh and make something to fit around the gizmo and keep debris out of the skimmer.
    Love TFP? Become a
    TFP Supporter!
    Re: ultra gizzmo
    just my luck i threw out a bunch of window screens not even a week ago, i was thinking of plastic wrap. Does the skimmer have to breathe?
    Jul 2009
    Houston, Texas
    9,427
    Re: ultra gizzmo
    Once the water temperature is below 70 degrees it should be fine to cover up the skimmer. When the water is warmer I would be concerned about mold or mildew forming in the skimmer if you seal it.
    Love TFP? Become a
    TFP Supporter!
