Thread: Mesh Safety Cover Advice
    I've looked through a lot of the old posts on the mesh safety covers, but there has been no consensus and no feedback on the In the Swim (GLI) branded cover. Not sure what my best bet would be between the following:
    1) http://www.intheswim.com/Pool-Opening-a ... Rectangle/ In the Swim (made by GLI). Standard Mesh. Cheapest option
    2) http://www.intheswim.com/Pool-Opening-a ... Rectangle/ Meyco Mesh. Standard Mesh. I doubt this is worth the price over the 1st but I could be wrong.
    3) http://www.intheswim.com/Pool-Opening-a ... Rectangle/ Covertech. Tight Knit Mesh
    4) http://www.intheswim.com/Pool-Opening-a ... Rectangle/ Loop-Loc. Tight Knit, brand speaks for itself.
    Sorry Loop-Loc, but I don't need it to hold an elephant. I've got a 10 lb dog now and assume small children in the future. I am more concerned about durability. If the Loop-Loc would last that much longer then I have no problem. Is the tight knit mesh worth an upgrade on 3 and 4? Would the cheapest option (1) be all I need?
    Let me know which you would go with given the prices.
    Thanks!!
    25000 Gallons - Sand - IG- Vinyl
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Mesh Safety Cover Advice
    I sell loop-loc, but I know you are trying to save money. I would maybe pick a brand that would match the anchor points of the loop-loc. That way if you hate the cheap cover you can upgrade with out having to re-drill. The price on the GLI cover is less than my cost for the loop-loc of the same size.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Like most people, I just want the best value for the money. If the Loop-Loc lasts twice as long and is much easier to use then I have no problem paying the extra. If any two of the middle options give me the same performance for a better price I am open to either of them also. If the cheaper option gives me even 80-90% of the service life and quality of any of the others, that would be my best choice.
    Last try.... Looking to make a purchase soon.... Anyone else been through this lately?
    I kind of went through this very thing recently (not exactly). I was deciding between a cover and a fence. I ultimately ended up with the pool fence for ease of use. Putting that net on after each swim isn't realistic and without it you lose all safety. Your options are more of a 'cover' than just a 'net' though, so you look to have different requirements than I had.
    New Pool: 22 x 35 | StoneScape Mini - Midnight Blue | ~17,500 gallons | Jandy Equipment - Built spring 2015 (click for details and pictures)
    Old Pool: 16 x 30 | QuartzBrite | 14,000 gallons | Pentair Equipment - Built summer of 2013 (click for details and pictures)
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    My take on pool covers is you get what you pay for. The less you pay, the shorter it lasts and the less sunlight it keeps out. Shorter life equals more aggravation and more sunlight means more likely for a swamp come spring. Aesthetics also comes into play if you are considering going very inexpensive, i.e. The blue tarp. I voted to go for clearer water and longer lasting, Merlin SmartMesh. I'll be able to give you a full evaluation of my choice in about 10 years. It is being made now.
    But the fact is resources are finite and choices have to be made. I made what I felt were sacrifices in other areas.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
