Thread: How often do you have leaks?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I was just wondering on average how often do you have a leak in your pool plumbing that requires some type of repair not counting freeze related events? I ask because I have experienced several unexpected events this year (2 random major pipe failures, 2 unions that started leaking that were fixed by tightening, and one valve that started leaking from the stem), most recently a hose bib connection that cracked, and partly sheered off at the neck, getting everything floor to ceiling wet in the pump room.
    Ike
    p.s. the connection that recently failed was a nylon hose bib, so not a corrosion issue, have have been vibration induced fatigue though, or thermal expansion cycles.
    30,432
    Re: How often do you have leaks?
    Interesting question. I have never had a leak in the plumbing of my pool in nine years. That said, my set-up is pretty basic and I have done a few mods to it over time but not much.
    New Brunswick Canada
    819
    Happens quite often up north, when people dont winterize properly or experience a lot of issues with Above Ground pools using covers, up here, we just dont freeze, AGP experience Icebergs, yep, totally frozen. A cover on the top can pull the sides inward or cause heat to melt on one side, iceberg shifts and wham, that one side is pulled as the iceberg is frozen to it.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Can't say yet Ike, but not heard of anyone having anything like that around here. We know yours aren't from freeze issues.....or at least I wouldn't think so down there.
    Essential Links:
