Results 1 to 7 of 7
Thread: TDH of a multiport valve
    Sep 2013
    Fresno, CA
    36
    Split off of this topic. JasonLion
    If you want the best flow with the least amount of TDH go with larger plumbing 3-4 inch, the TDH of a multiport valve, typically seen on sand filters if 50 ft head, and sand filters do not work well on low flow, the debris does not penetrate the media bed as far as it should and pressure will rise faster. A cartridge is a very good way to go, will also eliminate a backwash valve which can be a large amount of TDH. On your plumbing make sure to use 90 degree sweeps and not elbows, a 2" elbow on TDH is almost 9 ft head, so 90 degree sweeps or 45 degree elbows if you have to. You can find charts that will provide you with the amount of TDH for the plumbing that you plan yo use and then you can add it all up on the suction and pressure side to get to a number, then look the pump curve of the pump you plan on buying, then purchase accoringly. You ought to look at a vs motor or a 2 speed motor, you will like the electricity savings.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Pump sizing help for new inground design
    Head loss is dependent on flow rate so posting head loss numbers without flow rate is completely meaningless.
    Also, I am not sure where you are getting your head loss numbers but they are much too high.
    For example, a multi-port 2" backwash valve will have 50' of head loss at 182 GPM which is not really realistic. For a flow rate of 80 GPM, a backwash valve will have a head loss of about 10' of head (per Pentair spec sheet). Still high but not 50'. At 20 GPM, the head loss drops to 0.6' of head.
    A 2" 90 has 9' of head at 330 GPM. At 80 GPM, head loss for a single 90 is only 0.53' of head which is not much. At 20 GPM, the head loss drops to 0.033' of head.
    Also, sweeps have about half the head loss as 90s but 90s only make up a small portion of the total head loss in a typical plumbing system (~1% per 90). Normally, it isn't worth the effort to go with swept 90s. It is much easier to simply upsize the pipe. But even that has diminishing returns and plumbing a pad with 3 or 4" pipe is not easy. I would stick with 2.5" pipe.
    Lastly, from users experiences on this forum, sand filters work much better at lower flow rates than higher flow rates. Too much flow rate can push debris through the sand.
    Mark
    Sep 2013
    Fresno, CA
    36
    I got the numbers from Bob Seward of Hayward, at this years PIE(Pool Industry Expo) in Monterrey. Sorry that he did not specify the gpm for the friction head loss numbers.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Even a Hayward 1.5" Backwash valve has only 25' of head loss at 80 GPM. So I am not sure what he was talking about:
    http://www.hayward-pool.com/pdf/manuals ... P0714T.pdf
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by heythatguy
    Probably in sales
    Aug 2013
    South Florida
    39
    Re: TDH of a multiport valve
    So what about the Jandy Multiport valves vs using standard ball valves? At various flow rates, what would you recommend?
    8700 gals in planning stage, inground gunite, cartridge filter, three bubblers, sun shelf
    30,432
    Regardless of flow rate, I can tell you for certain that ball valves are temporary. As has been reported in many other pools AND my pool, you get about 2-4 years service at best from them and they "lock up".....not exactly sure why.
    IMO, even though I know they are used all the time, it is pointless to install your plumbing with Ball Valves......Go ahead and bite the bullet on the Jandy-type valves....money well spent
