Results 1 to 9 of 9
Thread: Hello from Texas!
    Jul 2013
    Nacogdoches, Texas
    6
    Hello from Texas!
    Finishing our first few months as a new pool owner. Reading and learning from fellow TFP forum members when I have the time.
    Here are my current levels:
    FC 4.5
    CC 0
    TC 4.5
    TA 90
    CH 280
    CYA 40
    pH 8.0
    2950 ppm salt
    [center:1nbz4di1]29K gal, IG PebbleSheen plaster with raised spa, Pentair IntelliFlo VS Pump
    Pentair Tagelus sand filter, Pentair Intellchlor 40 SWG, Pentair Kreepy Krauly pressure side pool cleaner
    [/center:1nbz4di1]
    Feb 2008
    Denton, TX
    5,061
    Re: Hello from Texas!
    Welcome to TFP!
    I'd get your pH down. You really want it between 7.2 and 7.8. It's critical that you keep your pH in check during this first year that your pool is up.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    Jeff
    Jul 2013
    Nacogdoches, Texas
    6
    Quote Originally Posted by 257WbyMag
    Welcome to TFP!
    Just added 28 oz muriatic acid as the poolcalculator.com suggested. Will test pH again tomorrow. Added same amount last week and it dropped to 7.5 for a few days. Is adding muriatic acid "normal" practice in a SWG pool?
    [/center:1nbz4di1]
    Feb 2008
    Denton, TX
    5,061
    Yes. Over the first year as your plaster cures, your pH will be rising a good deal. Couple this with the fact that you operate a SWCG (also raises pH constantly), daily additions of MA will likely be needed. You might consider bringing your TA down a bit. This will help.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    In addition to what was said above, for a swg pool you really want your cya up in the 70-80 ppm range.
    Mar 2011
    Houston, Texas
    413
    My pool is almost 3 years old and I have a SWG also. I'm still adding about a quart of MA each week to keep my pH in check. Borates and lower TA will help. The good news is that's about the only thing I need to add to my pool, except for the occasional topping up of CYA and borates.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Nice pool there. Welcome!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Really nice indeed!! Welcome to TFP!
    Essential Links:
