Thread: cleaning rust on ladder while pool is empty
    As I type, my water is being completely drained from the pool and I thought about cleaning the ladder without removing it from the decking (concrete). It only has some mild rust (right above the water line) and I will not recirculate the cleaning agents thru the pump.
    Is there an easy way to do this?
    Thanks
    27K Vinyl IG Pool
    18x36, Aquarite with Goldline T-15 SWG,
    Hayward 244T Sand Filter, 1.5 HP Hayward Super Pump w/ AO Smith B129 Motor
    Taylor 2006 Test Kit
    NW Louisiana
    30,431
    Re: cleaning rust on ladder while pool is empty
    If it's pretty light rust, I have used a little WD-40 and some reasonably fine steel wool with good results. If it's pretty deep, I am not sure what to suggest to take it off and keep it off. Others will have a batter take on that.
    Feb 2008
    Denton, TX
    5,061
    Agree with duraleigh here. WD-40 or Kroil with some 00 steel wool should get it.
    Jun 2007
    New Jersey
    653
    I have a recipe for removing rust from chrome bumpers that works great. Since I have a swim-out and steps my pool has no ladders, so I haven't tried it on one. I did clean up the corrosion on the trim ring on my light this way. Anyway, try dipping a wad of aluminum foil in a small cup or bowl filled with DietCoke. I've had amazing results with this on bumpers/trim. It's something about the phosphoric acid in the Coke. Diet is better because the sugar in regular gets sticky.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    This stuff removes rust stains from fiberglass almost like magic. It probably will work on stainless as well. A stainless steel polish should do the trick as well.
    http://www.amazon.com/dp/B0000AY4QY/?ta ... 0mssf2zm_b
    9500 gallon in ground gunite with fiberglass overlay! :( :( :( 26 x 14
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    It's not recommended to use steel wool on stainless steel. The scratching and embedding of iron particles from the steel wool will make the rusting problem return to a greater degree than it was initially. Here's a link with a description of the issue and recommendations for removing rust from stainless steel. You can find many more references to the same by goggling "embedded iron in stainless steel". Steel wool is made from a very low carbon steel that is substantially iron.
    http://www.bssa.org.uk/topics.php?article=55
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
