Results 1 to 7 of 7
Thread: Baracuda G3 Disconnecting at Main Body
    The cassette is disconnecting where it screws into the main body of the cleaner. Threads look good and I have tightened really tight but it still manages to disconnect itself. Maybe there is excessive vibration or something like that causing itself to unscrew itself?
    The cleaner is in good shape so not sure where to go from here. I have attached a pic so you can see where it is unscrewing itself during operation.
    Thanks for any advice.
    Feb 2008
    Denton, TX
    5,061
    Re: Baracuda G3 Disconnecting at Main Body
    Welcome to TFP!
    I owned a G3 for many years and have not had that happen. So you snug it down good and it keeps undoing itself?
    yep it keeps undoing itself, its an old unit so maybe the threads although look fine are just not working correctly
    Feb 2008
    Denton, TX
    5,061
    Thought it looked a little old. Probably just time to retire it.
    May 2013
    California
    46
    That happens a lot with the old G4 cleaners by Zodiac. I have had it happen to one G3 on my route. The threaded area gets stripped. You can't really see it with your eyes but it is stripped enough not to hold together any longer. That part is about 1/3 the price of a new cleaner...
    I just use duct tape on it and the cleaner works fine. Tape the nut and problem is solved. The tape will wear off in a few months and just re-tape it. Of course the cleaner is meant to swivel right at that point so try not to tape it too high up. The G3 is being retired by Zodiac this year and replaced with the much superior Zodiac T3.
    thanks everyone, i have decided to retire my 10 year old cleaner, it runs 365 days a year since i live in South Florida so it was a real warrior but of course the hoses and internal parts are still servicable
    May 2013
    California
    46
    In that case I recommend "The Pool Cleaner" by Poolvergnuegen. this is what I replace all of my customer's suction side cleaners with. Got about 14 on my route right now. They work great.
