Results 1 to 7 of 7
Thread: Solar covers and Intex skimmer
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Hello everyone, we just purchased a 15'x42" Intex metal frame pool about a month ago. I was given a solar cover from a coworker and have a question about the Intex floating skimmer. I'm worried about the cover blocking the skimmer. What is everyone doing to keep the skimmer clear of the cover? I haven't fully trimmed the cover yet, right now I just have the cover draped over the side so it doesn't block the skimmer. Will the cover block the skimmer or will it still work?
    I was thinking of trimming the opposite side and leaving an overhang on that side so the cover doesn't interfere with the skimmer or making some type of U shaped floating thing to keep the cover off the skimmer.
    If you have pics and links to you or others have done that would be great.
    Thanks in advance.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Solar covers and Intex skimmer
    Welcome to the forum.
    The cover will block the skimmer, but there is no need to run circulation through it when you have the cover on.
    With the cover in place, it can't do much good skimming at all. I would suggest
    pulling the hose off the suction fitting and letting the pump pull the suction from there.
    Essential Links:
    Sep 2013
    El Cajon CA
    126
    So basically it will pull from the bypass on the bottom if the cover is on.
    Also what is the concensus on leaving the cover on? I have a blue solar cover and I live in So Cal. Should I leave the cover on or take it off during the day?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    All depends on how much direct sun the pool gets, what the ambient air temp is, what the relative humidity is, and how much wind there is. Basically, if the air temp is somewhat above the pool temp, the winds are low, the humidity is not extremely low and the pool is getting direct sunlight...then in those conditions I would certainly have the cover off if I wanted to warm the pool water.
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by linen
    OK thanks. We are getting temps above what the pool is at and around 40% humidity and we generally don't have bad winds, just a small breeze across the pool. So I should leave the cover off during peak sun hours?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would give it a try. By a small breeze, do you mean constant, or just occasionally?
    Sep 2013
    El Cajon CA
    126
    Sometimes constant, sometimes constant. Depending on direction of wind. My backyard is fenced and blocks most of it but we get occasional breezes mostly. The top of the pool is usually smooth if that helps.
