Thread: How do I know what size pool hose to buy for vaccuums?
    Sep 2013
    Central Florida
    21
    As I mentioned in my prior post I am new to owning a pool. I now realize I don't know what kind of hose to buy for the vacuum. There was nothing left by the prior residents. I watched a few you tube items that indicate to feed it through the water skimmer thing and into the spot where the bucket would be but do I just measure the middle of the pipe to know if I need 1.25 or 1.5?
    Its annoying no pool supplies were left at this house at all just the pool itself so am buying things as I find out I need them. Just saw the vacuum and didn't realize I should have one to do on the bottom. With a screened in pool how often should you vacuum?
    Also anything else I should thing about buying?
    I bought the test kits
    I bought the pole.
    I bought the net (though thought with the screened in pool I would not use it much)
    I bought the scrubber
    I am now looking at the hose and a vacuum
    Anything more? and to reiterate my question above how do I determine if its 1.25 or 1.5
    Brand new pool owner
    Size of pool - appx 20,000 gallons
    Filter - DE
    Inground pool plaster/pebble
    (Not asked to be revealed but screened in pool enclosure)
    Do not know flow rate of pump
    22,539
    Re: How do I know what size pool hose to buy for vaccuums?
    It's very likely that it's 1½". Or to put it another way. It's highly unlikely that it's 1¼".
    However, I'd suggest that you buy a vacuum plate that fits in the skimmer over the basket and use that. It'll have a 1½" vacuum port on it.
    Sep 2013
    Central Florida
    21
    Oh interesting I didn't know they had ones that fit OVER the basket. I''ll have to look for that. The two videos I watched online had the people taking the baskets out and putting the hose into the pipes under the basket.
    Filter - DE
    Jan 2012
    'burbs of Augusta, Georgia
    7,252
    I've got a cover over my pool so have learned that I rarely have to do any big vacuuming jobs. Yet now and then need a little worm pick up or light cleanup and recently purchased a "Pool Blaster" rechargeable vacuum that fits on to the telescoping pole and makes for fast clean up. Since you have a bird cage you might not need a lot of vacuum? Worth considering, y'know?
    http://www.familypoolfun.com/shop?categ ... 7aodcbyavq
