Results 1 to 11 of 11
Thread: Muratic or Hydrochloric Acid
    Post split from another thread by SeanB - I think we were starting to confuse what should have been a relatively simple issue.
    Quote Originally Posted by mcftlf
    On a side note one of my co-workers who owns a 20000 g IG pool saw me a Lowes buying MA and when he found out what I was buying it for says ..."You Cant put that in your pool!"
    Thanks again for all the help...This is almost getting fun! Is that possible?
    Isn't it amazing to be able to separate fact from fantasy? Why wouldn't you be able to put Hydrochloric Acid in a pool, where it will release Chlorine ions into your water? Wouldn't 5 seconds of reflection tell you that it's probably the best acid to use in your pool BECAUSE it's hydrochloric acid?
    It's like the pool store guy telling me "Oh, you don't want to use bleach--it raises your total dissolved solids!" What is that dissolved solid it's adding? Salt! Sodium Chloride (Hey! More chlorine ions!) And if you use bleach for 5 years in your pool you still won't reach the salt levels needed for .....your salt-water generator! So....fact vs fiction.
    Stay ahead of your water!
    30,316
    Re: Long time reader, first time poster
    I think he put in muriatic....not hydrochloric.
    If I'm not mistaken, muriatic acid is hydrocloric acid.
    30,316
    Yes, but in a different concentration. 31.5% is the muriatic concentration and it's what's generally referred to on the forum for pool use.
    (Yes, there are other concentrations but that discussion belongs in the "deep end". We are in "just getting started")
    Guest
    Quote Originally Posted by CarlD
    I'm a newbie here, y'know.
    Don't worry about it Carl, Just read the pool school section and you will soon learn that it only takes 5 minuts a day to stay ahead of your water!
    (One thing I have ALWAYS appreciated about Carl, besides his knowledge of pools, is is sense of humor! )
    Mod Squad JohnT's Avatar
    SW Indiana
    9,171
    Quote Originally Posted by waterbear
    Pools are hard work! I went out to test my water and check the pool last night, and I was out there for 45 minutes. Sure, for 43 minutes I was kicked back in my chair in the poolhouse with a beer listening to music , but I was keeping an eye on things, and I had to work pretty hard for 2 minutes testing my water, adding acid and switching my solar panels off BY HAND.
    Butterfly's Avatar
    South Carolina
    10,045
    Absolutely! and....Welcome to the forum!
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,965
    Quote Originally Posted by frustratedpoolmom
    Gotta agree with CarlD. Once again he's right on the money, IMHO!
    Ditto. I thought maybe I was missing something when he said his advice would be controversial....
    Thanks, guys., I felt funny contradicting FrustratedPoolMom, who wanted the OP to push CYA to 40 at the start.
    No need, I'm still learning, and everybody has to figure what range works best for their pool, like a curve...hehehe you are absolutely welcome to contradict me anytime.....
    http://www.PerfectlyClearPoolService.com
    I guess most people don't realize that "Muriatic" acid is really a version of hydrochloric acid.
    Jun 2008
    Marana, AZ
    347
    Re: Muratic or Hydrochloric Acid
    Funny - the local Patio Pools store sells muratic acid! Does that make them wierd? Or does this mean I maybe can actually trust this store? I sure like the swim shirt I got there!
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Guest
    Quote Originally Posted by Swimgirl
    Just about all pool stores sell muriatic acid. It's a standard pool chemical.
