Thread: De filters, DE by weight or volume?
    I have read a thread that suggests that DE should be added not by Suggested weight (i have a Hayward 6020 requiring 7.5lbs) but by volume? I have been putting the DE in a bag and weighing it to ensure i *** the correct amount, is this a bad idea? It seems crazy that a company like hayward would suggest 7.5lbs of DE is they actually meant 7 1/2 1lb coffee jars!
    23,000 IG vinyl
    sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: De filters, DE by weight or volume?
    Welcome to TFP!
    You measure your DE by weight. You can get a scoop that is designed to hold 1/2 pound to avoid a scale.
    38,284
    I would still weigh any scoop to find out what it holds. It is near impossible to get more than 0.9 pounds in my 1 pound scoop.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I also say by weight, as I have found the scoops vary considerably depending on how tight your pack the DE
