Thread: planning and preparing for a liner replacement
    Jun 2011
    Ontario, Canada
    20
    I plan on replacing the liner next spring. The thing is my pool water's gotten away from me for the last few weeks and is looking rather swamp-like. Should I spend the time and money getting the water in balance before closing the pool?
    My hectic schedule is telling me doing so would be a waste seeing as the liner's going to be ripped out anyway; on the other hand, my heart winces every time I look and see what once was crystal clear water now appear like a bog from middle earth.
    I would appreciate your thoughts.
    24k gal (100k L) inground vinyl|Watermaid EZY SWG|Hayward 1/2 hp & sand filter
    Mar 2013
    New Hampshire
    351
    Re: planning and preparing for a liner replacement
    When are you planning on closing it for the winter? Once it is closed you will not have to look at it correct?
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,082
    I'm in the same boat. We had a major tear in our 15 year old liner....and lost almost 16k gallons of water. Patched it up and added enough water to keep the walls from caving in. I'll add bleach every now and then just to keep the bugs away.....but other than that I've said forget it. No need dumping the cash into the water, just to drain it next year.
    Jun 2011
    Ontario, Canada
    20
    doobs - at the latest, mid-October; and, yes, once it's closed I won't have to open until next spring for the liner replacement
    Leebo - the difference between our situations is that your water was probably in balance before the tear happened whereas mine's a mess. When you say "walls caving in", do you mean the liner walls or the concrete?
    Jul 2011
    Eastern Ohio
    7,082
    Either way you'll end up dumping all the water, so I'd still say forget it. Not worth SLAMMING for a few weeks of blue water. All inground pools run the risk of the weight of the dirt pushing the walls inward causing the pool to "collapse". The weight of the water helps hold back the dirt.....acting almost like a retaining wall.
